Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Robot Extensions Spreadsheet Calculator2012
27 REPLIES 27
Message 1 of 28
jad.dellel
6775 Views, 27 Replies
Question client:
"Bonjour,
J'ai bien réussi à installer la version 2012 de Robot Professionnal et à l'enregistrer, mais lorsque je lance le raccourci Robot Extensions - Spreadsheet Calculator 2012, j'obtiens une erreur et les applications sont impossibles à utiliser.
Que faire ?"
Customer's question:
" After RSA2012 installation, I tried to launch Robot Extensions- SPreadsheet Calculator 2012 but no applications were there, I can't use it, what I have to do? "
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
27 REPLIES 27
Message 2 of 28
jad.dellel
in reply to: jad.dellel
Bonjour,
Robot Extensions Spreadsheet Calculator2012 sera bientôt disponible pour les clients sous Souscription et téléchargeable depuis: http://subscription.autodesk.com/
Cordialement.
Robot Extensions Spreadsheet Calculator2012 will be downloadable, soon, for customers from: http://subscription.autodesk.com/
Jad DELLEL
Message 3 of 28
jad.dellel
Bonjour,
Robot Extensions Spreadsheet Calculator2012 est disponible actuellement au téléchargement depuis le site de Souscription:
HI,
Robot Extensions Spreadsheet Calculator2012 is now available to download from
Jad DELLEL
Message 4 of 28
Romanich
Spreadsheet Calculator 2012 not working with Excel 2010 Smiley Sad
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 5 of 28
jad.dellel
in reply to: Romanich
You need to have the 32bit version of office:
Jad DELLEL
Message 6 of 28
Romanich
Thanks Jad, I installed Excel x32bit version and saw this:
Roman Zhelezniak
Message 7 of 28
WASSIMSAID1507
Hi
I am installing spread sheet calculator 2012 and I have windows 7 pro 64 bits+Microsft excel 2003.
the program runs but it is in demo mode.
Can I have a solution?  thank you.
Wassim Said
Message 8 of 28
Romanich
in reply to: WASSIMSAID1507
Jad deleted post, but this tip there: download & install in trial mode Autodesk Quantity Takeoff 2012 32Bit. Reboot after install & try to run spreadsheet calculator. Thanks Jad for this hidden trip 🙂
Roman Zhelezniak
Message 9 of 28
jad.dellel
Well done Romanich,  you're a good follower of our RSA forumSmiley Happy
I deleted the tip because I'm waiting for better solution and I'm not sure It will work for all the users
Jad DELLEL
Message 10 of 28
jad.dellel
Hi All,
RSA/RSAPRO 2012 licensing error which appears on 64-bit operating systems inside RESC (former name ESOP), Experts and Apilogs can be cured by installing appropriate one of the following hotfixes:
License error hotfix for 64-bit OS - RSA,
License error hotfix for 64-bit OS - RSAPRO
Both are available on Autodesk Robot Structural Analysis Professional Services & Support page, under RSA 2012 and RSAPRO 2012 sections.
In few days Apilog, Expert, and RESC Content installations on Subscription will be supplied with this hotfix adding missing license element during installation.
I will inform you when exchanging subscription installations is finished.
Best regards,
Bonjour à tous,
Le problème de détection de licence rencontré sous RSA/RSAPRO2012 pour Spreadsheet Calculator, Expert et Apilog peut être corrigé en installant le "Hotfix" correspondant à votre version:
Cordialement.
Jad DELLEL
Message 11 of 28
AMOCERANALYSE
Bonjour
Le correctif fonctionne:
mais ou peux t on trouver les différences entre les versions
Logiciel DALLIA Version 1.3.3034        2012
Logiciel DALLIA Version 1.3.2930        2011
La seule différence est-elle la supression du bouton imoprtation charge qui ne fonctionnait pas et qui devait fazire l'objet d'un correctif pour la nouvelle version .....
Message 12 of 28
labrousse
Bonjour,
Est-il possible de faire appel à un autre tableur que Excel (par exmple le tableur d'Openoffice) ? en jouant sur les Clés Registre
Message 13 of 28
jad.dellel
in reply to: labrousse
Bonjour,
Malheureusement, ce n'est pas possible, c'est seulement développé sous MS office 32 bits.
Personnellement, j'ai essayé de le faire tourner sous Openoffice, ce dernier n'interprête pas les Macros Spreadsheet Smiley Sad
Cordialement.
Jad DELLEL
Message 14 of 28
labrousse
in reply to: AMOCERANALYSE
Bonjour,
Concernant notre problème avec l’Excel d'office 2010 virtualisation, le problème ne vient-il pas de la ligne de commande demandant l'ouverture d'Excel ? L’exécutable d’Excel n’étant pas à l’emplacement  « habituel ».
Est-il possible de vérifié le chemin utilisé pour appeler Excel ?
Merci d'avance
Florent Labrousse
Ingénieur IFMA
Message 15 of 28
Bonjour, j'ai également un problème lors du lancement de l'application:
je n'ai pas accès au navigateur: Bibliothèque de modèle.
j'ai suivi les instruction de l'erreur 1000 sans succès
Voici le rapport de ESOPSetup.exe:
Diagnosis report
MS Excel
Basic functionality:
Creation - OK
Excel addins (xla) - opening - OK
(C:\Program Files\Autodesk\Autodesk Robot Structural Analysis 2012\RESC\cfg\esop.xla)
Run VBA macro test - OK
(esop.xla!ESOP_Open)
Check AV addin for Office - Not installed
Required version - OK
(12.0.4518)
Required service packs - OK
Security level - OK
VBProject access - OK
Components:
MS Equation - OK
System32 components:
atl.dll - FAIL
(C:\Windows\system32\atl.dll ver. 3.5.2284.0 - not registered)
ComDlg32.ocx - OK
(C:\Windows\system32\ComDlg32.ocx ver. 6.0.84.18)
MSComCtl.ocx - OK
(C:\Windows\system32\MSComCtl.ocx ver. 6.1.97.86)
MSFlexGrd.ocx - OK
(C:\Windows\system32\MSFlxGrd.ocx ver. 6.0.84.18)
RichTx32.ocx - OK
(C:\Windows\system32\RichTx32.ocx ver. 6.0.88.77)
TabCtl32.ocx - OK
(C:\Windows\system32\TabCtl32.ocx ver. 6.0.90.43)
Program components:
esopsys.dll - OK
(C:\Windows\system32\esopsys.dll - registered)
EDB.dll - OK
(C:\Windows\system32\edb.dll - registered)
ECore.dll - OK
(C:\Windows\system32\ecore.dll - registered)
Esop.dll - OK
(C:\Windows\system32\esop.dll - registered)
LMan.dll - OK
(C:\Windows\system32\lman.dll - registered)
Pref.dll - OK
(C:\Windows\system32\pref.dll - registered)
SReg.ocx - OK
(C:\Windows\system32\sreg.ocx - registered)
Settings:
Language resources - OK
(33)
ROBOT OFFICE Common
Required version - Runtime detecting
(Ver. 21.9 Path:)
COM components:
About.dll - FAIL
(C:\Windows\system32\About.dll - not registered)
CSConvert.dll - OK
(C:\Windows\system32\CSConvert.dll - registered)
Numerics.dll - OK
(C:\Windows\system32\Numerics.dll - registered)
RbtSaveAs.Dll - FAIL
(C:\Windows\system32\RbtSaveAs.Dll - not registered)
ROHtml.Dll - OK
(C:\Windows\system32\rohtml.Dll - registered)
SysPaths.Dll - OK
(C:\Windows\system32\syspaths.Dll - registered)
Data bases:
Existing - OK
(Path:Data\Prof\ruserpro.mdb)
Summary
27 items - OK
3 items - FAIL
30 items processed
 Je suis Windows 7 pro 64bit....
Message 16 of 28
labrousse
J'ai effectué la manip indiqué au lien suivant : l'erreur 1000
Voici le rapport que j'obtient  : voir pièce jointe.
J'ai deux erreur :
   cip.dll - FAIL
   AnsysWB\AWBEsop.dll - FAIL
Pourquoi ? Please
Message 17 of 28
jad.dellel
Monsieur Labrouse,
Concernantle le chemin que vous avez pour l'exécutable de MS Excel, il s'agit du bon chemin dans lequel cette application s'installe sous les plateforme 64bit.
Jad DELLEL
Message 18 of 28
jad.dellel
Florent Labrousse a dit:
"J'ai effectué la manip indiqué au lien suivant : l'erreur 1000
J'ai deux erreur :
   cip.dll - FAIL
   AnsysWB\AWBEsop.dll - FAIL"
Monsieur Labrousse,
Concernant les 2 erreurs que vous avez obtenues, elles sont liées à des applications que vous n'avez pas sur votre machine (ansys), ces 2 erreurs n'empêche pas l'exécution de spreadsheet calculator.
Jad DELLEL
Message 19 of 28
jad.dellel
Bonjour gpascau,
Pourriez-vous ajouter une capture d'écran de ce que vous avez lors du démarrage de spreadsheet calculator, pour mieux comprendre votre problème?
Merci.
Jad DELLEL
Message 20 of 28
Certainement! la voici:
Comme vous pouvez le constater l'explorateur est activé mais la fenêtre n'apparait pas!
Merci pour l'aide que vous m'apportez.
Cordialement
