Hello, i've been using RSAP 2011 and after new install of 2012 version i get this message, when i try to calculate model.
It's the same problem when i create a new model.
But when i try small structural frame or meshed object (small number of calculation nodes) everything works fine.
Maybe this is licensing problem?
any ideas?
Solved by Rafal.Gaweda. Go to Solution.
Hi
It is
THE SPARSE SOLVER ERRORS : 3300 Open file error -> problem with opening temporary file
Clear windows %temp% folder and \ or use different solver (multithreaded, iterative for large models)
Oh, thanks, changing the solving method worked !
Maybe there's some information about those solving methods, their field of uses and differences? It would be great to know more about the "brains" of RSA:
Frontal
Skyline
Sparse
Sparse M
Iterative
Multi-threaded solver
HI, check help = link below
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-C1CA3EC7-0C8E-4E11-9BD3-38C4F12494B-110.htm
