Hello all,
I curently designing a 2 story concrete building. I finished with the structure and now i would like to use Robot in calculating the foundations. Usualy i'm using manual calculations made in excel. But this time i would like to use Robot.
The soil seems to be very bad in the location of the site: conventional pressure of the soil 150kPa.
My thought is to do like this:
-remove all the fixed supports from my structure;
-model some reversed T concrete beams as the continuous foundations;
-assign elastic springs as support to the reversed T beams.
Now my questions are:
1. will Robot be able to dimension my concrete beams to the corect section ?
2. how will i determine the Kz coefficient ? does Robot now how to do that automaticaly ?
If you have any suggestions on how to do this, it will be appreciated.
Best regards,
MariusR.
Solved by Artur.Kosakowski. Go to Solution.
