Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
ROBOT - Check Values not equal to zero
5 REPLIES 5
857 Views, 5 Replies
I am creating a model of a glass screen. The stresses in the panel given to me by robot do not match my expectations.
I found that the reason for that might that the check values are not equal to zero in the reaction table. Is there a way to solve it? (I already remeshed the model and checked all my inputs for errors)
5 REPLIES 5
Artur.Kosakowski
The possible reasons can be the fact that reported instability warning was ignored or the use of non linear analysis (then the difference can is some cases be justified). Can we you attach the model and indicate where (which load case) you found this difference please?
Artur Kosakowski
in reply to: Artur.Kosakowski
I double checked for that, knowing it might be an issue.
I have attached the model. The discreptancy occurs in all lateral load cases, I am particularly interested in the combination 1.35Gk+1.5Wk+1.05Qk (PEUTZ).
Artur.Kosakowski
Please use Sparse solver (Job Preferences > Structure analysis) for calculations.
Artur Kosakowski
That solved my problem!
Thank you!
Artur.Kosakowski
Correction for the Sparse solver has been done in SP1 for Robot 2013.
Artur Kosakowski
