Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
ROBOT API Release Orientation
19 REPLIES 19
Message 1 of 20
arseneATingerop
925 Views, 19 Replies
Hi
I'm trying to get the release data in a bar in C# but I'm not sure of the switch between start and end .
From the label, I get StartNode.UX... but the data for bar.GetLabel(IRobotLabelType.I_LT_BAR_RELEASE).Data.StartNode corresponds to the bar.EndNode and so on.
I've checked the property bar.ReversedRelease but with no effects.
Here are some pieces of information I got from label
   Type Label = I_LT_BAR_RELEASE
   roblabel name = ENC-ART
   release_data.StartNode.UX = I_BERV_NONE
   release_data.StartNode.UY = I_BERV_NONE
   release_data.StartNode.UZ = I_BERV_NONE
   release_data.StartNode.RX = I_BERV_NONE
   release_data.StartNode.RY = I_BERV_NONE
   release_data.StartNode.RZ = I_BERV_NONE
   release_data.EndNode.UX = I_BERV_NONE
   release_data.EndNode.UY = I_BERV_NONE
   release_data.EndNode.UZ = I_BERV_NONE
   release_data.EndNode.RX = I_BERV_FIXED
   release_data.EndNode.RY = I_BERV_FIXED
   release_data.EndNode.RZ = I_BERV_FIXED
Any ideas ?
Arsene HAW
INGEROP
19 REPLIES 19
Message 2 of 20
This is the way how it is created.
I will check GET also
    Dim RLabel As RobotLabel
    Dim RelData As RobotBarReleaseData
    Dim EndData As RobotBarEndReleaseData
    Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_BAR_RELEASE, "MY RELEASE")
    Set RelData = RLabel.Data
    Set EndData = RelData.StartNode
    EndData.RY = I_BERV_STD
    Set EndData = RelData.EndNode
    EndData.RX = I_BERV_STD
    RobApp.Project.Structure.Labels.Store RLabel
Rafal Gaweda
Message 3 of 20
Unfortunately bar.ReversedRelease gives always FALSE it means that it is wrong in case of reversed release on bar.
Must be corrected by developers.
Rafal Gaweda
Message 4 of 20
igos
in reply to: Rafal.Gaweda
Hello Rafal,
Was this problem (with ReversedRelease property) corrected in new versions of RSA, for example 2014?
_________________________________________
https://ru.linkedin.com/in/igor-saltykov-8a68b726
Message 5 of 20
Rafal.Gaweda
in reply to: igos
Correction is planned to be released in SP2 for 2014.
SP2 will be available soon.
Rafal Gaweda
Message 6 of 20
igos
Ok, and whats about 2013 version?
Message 7 of 20
Rafal.Gaweda
in reply to: igos
Not planned to relase any more corrections to 2013.
Rafal Gaweda
Message 8 of 20
igos
Bad news about 2013!
Honestly, I try to NOT use new versions of RSA until at least three SP's released.
Yes, Robot is amazingly unreliable software, I've never seen such before.
Message 9 of 20
Rafal.Gaweda
in reply to: igos
As far as I remeber you have used it for years now 🙂
Rafal Gaweda
Message 10 of 20
igos
Yes, Rafal, you are correct. But not for full calculations and analyse, only for meshing (it's quite cool in Robot, seriously). Then convert whole meshed model into another program (which have no link with Revit).
Long "production chain" of course....
So, this question about releases - I wanted to add new function into converting program to transfer releases into another software. But, quite important properly for bars with only one end released is not working. I wasn't surprised, really 🙂
Message 11 of 20
Rafal.Gaweda
in reply to: igos
Igor
to L..A soft ?
only if reversed
 -> SP2 2014
Rafal Gaweda
Message 12 of 20
igos
to L..A soft ?
Yes, you are correct
only if reversed
-> SP2 2014
Yes, but sometimes in big model it's quite hard to find reversed bars, so waiting for SP2!
Message 13 of 20
arseneATingerop
in reply to: igos
Hello
About this old topic, I've recently used Autodesk Robot 2014 (version 27.0.4.4679 (x64)).
It  seems the "ReverseReleased" method has been corrected, as I sometimes get True or False.
Therefore, I thought that my problem was over and that I could change the actual implementation I had done, using for example an export as STR and parsing the "RELâchements" chapter... (not very convenient nor safe for future versions, I agree)
But, actually, when I tried the "ReverseReleased" + reading of the "UX, ... , RZ" value, I somehow now get the wrong values for "UX, ..., RZ" whereas "ReverseReleased" seems okay.
Could you please confirm the issue or is it my reading which is oncorrect ?
Thanks for your help...
Message 14 of 20
See below:
Example code
Public RobApp As RobotApplication
Private Sub CommandButton1_Click()
Set RobApp = New RobotApplication
    Dim Rbar As RobotBar
    Dim BarNumber As Integer
For BarNumber = 1 To 2
    Set Rbar = RobApp.Project.Structure.Bars.Get(BarNumber)
    If Rbar.HasLabel(I_LT_BAR_RELEASE) Then
        Set RLabel = Rbar.GetLabel(I_LT_BAR_RELEASE)
        Cells(1, BarNumber) = RelData.StartNode.UX
        Cells(2, BarNumber) = RelData.StartNode.UY
        Cells(3, BarNumber) = RelData.StartNode.UZ
        Cells(4, BarNumber) = RelData.StartNode.RX
        Cells(5, BarNumber) = RelData.StartNode.RY
        Cells(6, BarNumber) = RelData.StartNode.RZ
        Cells(7, BarNumber) = RelData.EndNode.UX
        Cells(8, BarNumber) = RelData.EndNode.UY
        Cells(9, BarNumber) = RelData.EndNode.UZ
        Cells(10, BarNumber) = RelData.EndNode.RX
        Cells(11, BarNumber) = RelData.EndNode.RY
        Cells(12, BarNumber) = RelData.EndNode.RZ
        Cells(13, BarNumber) = Str(Rbar.ReversedRelease)
 Next BarNumber
Set RobApp = Nothing
End Sub
Rafal Gaweda
Message 15 of 20
Hello, Rafal
I agree with the results for some bars but not for all of them, unfortunately...
May I join a model (not created by me) and a Excel file with a macro based on your code which shows the problem ?
Maybe it's because the file was recorded under version 26 ? or is in a wrong state ?
Arsène
Message 16 of 20
Sure.
Rafal Gaweda
Message 17 of 20
Here are my model and a excel file (my pieces of software are in C# but Excel VBA is easier to transmit)
I get {0,...0} on bar #19 and many more...
 Here is my code in Excel VBA
Sub Relacher()
    Dim fullpathname As String
    Dim BarNumber As Long
    RobApp.Interactive = True
    RobApp.Visible = True
    fullpathname = ActiveWorkbook.Path + "\Hall-2015-02-18.rtd"
    RobApp.Project.Open (fullpathname)
'For BarNumber = 1 To 2
    BarNumber = 19
'Next BarNumber
    RobApp.Project.Close
    RobApp.Quit (I_QO_DISCARD_CHANGES)
End Sub
Message 18 of 20
Because it is not "real" (with label) release. It is automatically generated release after bar spliting  \ dividing.
Rafal Gaweda
Message 19 of 20
Thanks for the explanation
 I agree and I haven't built the model myself, so I don't know how it has been built.
But, in such case, how can I get the release values on auto-generated releases on bars ?
One idea I got is that it's part of a superBar, for which maybe I can get a REAL LABEL ? Is it possible ?
Message 20 of 20
Is it possible ?
No.
Rafal Gaweda
