Discussion Groups
Robot Structural Analysis
Active Contributor
0 Kudos
Robot API - open and close project issues
254 Views, 5 Replies
01-01-2013 03:32 AM
First question : I want to close a Robot project without saving using API code 'Robot.Project.Close', and without closing RSA application.
But nothing happens. I would like to go back to the starting window (the grey one with 'Projects' And 'New Project' Option). But the project is still opened and still appears in the Robot window. How can I do that ? Is there a kind of 'refresh' script to add ?
Second question : I open RSA through API using
Dim Robot As New RobotApplication
Robot.Visible = True
Robot.Window.Activate
I would like the RSA window to come to the front, above the window form which the API script is launched (Rhino&Grasshopper in my case - it could be Excel). It is not the case with my script, RSA just appears in the task bar, but does not become visible. How can I do that ?
Guillaume
Product Support
1,303 Kudos
Re: Robot API - open and close project issues
01-02-2013 01:12 AM in reply to: guillaumeniel
IN fact robot can not open moer than 1 project so Close option does not work as you think.
Close just sets Modified flag onto false and then while loading (openining new file) program will not ask you whether to save changes in previous file. So Close project then open file.
Rafal Gaweda
Product Support
1,303 Kudos
01-02-2013 01:15 AM in reply to: guillaumeniel
After Robot.Visible = True it should be visible.
If you want it in foreground you have to use windows system functions, most likely using RobotApplication.Window.Handle
Rafal Gaweda
Active Contributor
0 Kudos
01-02-2013 12:30 PM in reply to: Rafal.Gaweda
OK,
Thanks.
Valued Contributor
46 Kudos
08-20-2014 07:30 AM in reply to: guillaumeniel
I would like to close the Project at the end of the sub after saving the changes.
"robot.project.close" seems nothing happens.
How can I close the Project or the application?
Thks
Product Support
757 Kudos
08-20-2014 11:55 PM in reply to: aruser
Try robot.Quit(IRobotQuitOption.I_QO_SAVE_CHANGES)
Artur Kosakowski
