Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
ROBOT API Member Type - Intermediate bracings
6 REPLIES 6
530 Views, 6 Replies
I am trying to create a routine to create, trough API, a member type definition to Steel Design where I can define the intermediate bracings positions. I developed a code, it chooses the correct option but ir does not writes the bracings positions and does not activates that option. Can anyone tell me what I am doing wrong?
Thanks...
Dim MTdata  As IRDimMembDefData
Dim MTpar As IRDimMembParamsE32
Dim Ptos As IRDimMembDefIntPsDataType
    Set LABEL = METALICA.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "COLUMNS_1")
    Set MTdata = LABEL.Data
    Set MTpar = MTdata.CodeParams
        MTpar.BuckLengthCoeffY = 10
        MTpar.BucklingDiagramY = I_DBD_E32_INTERNAL_BRACINGS
        MTpar.BracedY = False 'Not Sway
        MTdata.SetIntPsCoordValueType I_DMDIPDT_BUCKLING_Y, True
        MTdata.SetIntPtAddOption I_DMDIPDT_BUCKLING_Y, I_DMDIPOT_MANUAL_COORDS, 0
        MTdata.SetIntPtValues I_DMDIPDT_BUCKLING_Y, 1, 0, 1
        MTdata.CodeParams = MTpar
        METALICA.Project.Structure.Labels.Store LABEL
Tags (2)
6 REPLIES 6
Rafal.Gaweda
MTpar.BracedY = True ' = Non-Sway
I am checking the rest
Rafal Gaweda
Rafal.Gaweda
in reply to: Rafal.Gaweda
You are right, it does not work
We found the bug 😞
Rafal Gaweda
Rafal.Gaweda
Corrected in ARSA 2015 SP1
Rafal Gaweda
xblanchet
I have exactly the same problem as @Anonymous, with exactly the same script.
You said, in your last message, that the problem was Corrected with RSA 2015 SP1 and I have RSA 2018.
Can you help me ?
regards,
Rafal.Gaweda
in reply to: xblanchet
Hi @xblanchet
I ma very sorry, You are right. The issue is back.
It worked well in 2015SP1 and 2016.
Need to be fixed again.
Thank You for reporting it.
Rafal Gaweda
xblanchet
So sad ! Smiley Sad
I can not continue my program without this piece of script
