Robot API - how to modify units
9 REPLIES 9
Message 1 of 10
guillaumeniel
1433 Views, 9 Replies
I would like to change default units for forces with Robot API, and set N instead of kN.
Here is my script :
Dim projPref As RobotProjectPreferences
projPref = Robot.Project.Preferences
projPref.Units.Set(IRobotUnitType.I_UT_FORCE, N)
The last line does not work (red part).
What is the appropriate syntax to set the unit to Newtons ?
9 REPLIES 9
Message 2 of 10
Dim Robot As New RobotApplication
Set projPref = Robot.Project.Preferences
Dim RU As RobotUnitData
Set RU = projPref.Units.Get(I_UT_FORCE)
RU.E = False
RU.Name = "N"
RU.Precision = 2
projPref.Units.Set I_UT_FORCE, RU
Rafal Gaweda
Message 3 of 10
Thanks.
Message 4 of 10
It works for forces, but it does not work for moments. Here is my code :
RU = projPref.Units.Get(IRobotUnitType.I_UT_FORCE)
RU.E = False
RU.Name = "daN"
RU.Precision = 2
projPref.Units.Set(IRobotUnitType.I_UT_FORCE, RU)
RU = Nothing
RU = projPref.Units.Get(IRobotUnitType.I_UT_MOMENT)
RU.E = False
RU.Name = "daN*m"
RU.Precision = 2
projPref.Units.Set(IRobotUnitType.I_UT_MOMENT, RU)
I don't get any error message, but it does not work for moment, whereas it works for forces.
Message 5 of 10
Dim RUCD As RobotUnitComplexData
Set RUCD = projPref.Units.Get(I_UT_MOMENT)
RUCD.E = False
RUCD.Name = "daN"
RUCD.Name2 = "m"
RUCD.Precision = 2
projPref.Units.Set I_UT_MOMENT, RUCD
Rafal Gaweda
Message 6 of 10
Thanks.
Message 7 of 10
Sorry to come back again to this topic which appears as solved, but there is still a problem with units in my script. In Robot, if I go to Tools>Project Preferences>Units>Force, I can see that kN changed to daN, as I wanted.
The problem is that when I calculate and then display the forces array (Results>Forces), forces are still in kN in the array. So I have to go to  Tools>Project Preferences>Units>Force and quit, and then the array is updated and forces appear in daN.
So there is a kind of "refresh" problem for units.
Same problem if I want to diplay forces diagrams. Unless I open Tools>Project Preferences>Units>Force, forces are still in kN.
How can I fix this ?
Message 8 of 10
That's interesting, we have to check it.
Rafal Gaweda
Message 9 of 10
Any answer to my problem ?
Message 10 of 10
It will not be possible for us to investigate this situation before the next week.
Try to add projPref.Units.Refresh at the end of your code.
Artur Kosakowski
