Discussion Groups
Robot Structural Analysis
Active Contributor
guillaumeniel
Robot API - how to modify units
496 Views, 9 Replies
12-15-2012 02:53 PM
I would like to change default units for forces with Robot API, and set N instead of kN.
Here is my script :
Dim projPref As RobotProjectPreferences
projPref = Robot.Project.Preferences
projPref.Units.Set(IRobotUnitType.I_UT_FORCE, N)
The last line does not work (red part).
What is the appropriate syntax to set the unit to Newtons ?
Please use plain text.
Product Support
Rafal.Gaweda
Re: Robot API - how to modify units
12-17-2012 02:43 AM in reply to: guillaumeniel
Dim Robot As New RobotApplication
Set projPref = Robot.Project.Preferences
Dim RU As RobotUnitData
Set RU = projPref.Units.Get(I_UT_FORCE)
RU.E = False
RU.Name = "N"
RU.Precision = 2
projPref.Units.Set I_UT_FORCE, RU
Rafal Gaweda
Active Contributor
guillaumeniel
12-17-2012 12:50 PM in reply to: Rafal.Gaweda
Thanks.
Active Contributor
guillaumeniel
12-17-2012 01:02 PM in reply to: Rafal.Gaweda
It works for forces, but it does not work for moments. Here is my code :
RU = projPref.Units.Get(IRobotUnitType.I_UT_FORCE)
RU.E = False
RU.Name = "daN"
RU.Precision = 2
projPref.Units.Set(IRobotUnitType.I_UT_FORCE, RU)
RU = Nothing
RU = projPref.Units.Get(IRobotUnitType.I_UT_MOMENT)
RU.E = False
RU.Name = "daN*m"
RU.Precision = 2
projPref.Units.Set(IRobotUnitType.I_UT_MOMENT, RU)
I don't get any error message, but it does not work for moment, whereas it works for forces.
Product Support
Rafal.Gaweda
12-18-2012 02:23 AM in reply to: guillaumeniel
Dim RUCD As RobotUnitComplexData
Set RUCD = projPref.Units.Get(I_UT_MOMENT)
RUCD.E = False
RUCD.Name = "daN"
RUCD.Name2 = "m"
RUCD.Precision = 2
projPref.Units.Set I_UT_MOMENT, RUCD
Rafal Gaweda
Active Contributor
guillaumeniel
12-18-2012 01:10 PM in reply to: Rafal.Gaweda
Thanks.
Active Contributor
guillaumeniel
12-21-2012 02:21 PM in reply to: Rafal.Gaweda
Sorry to come back again to this topic which appears as solved, but there is still a problem with units in my script. In Robot, if I go to Tools>Project Preferences>Units>Force, I can see that kN changed to daN, as I wanted.
The problem is that when I calculate and then display the forces array (Results>Forces), forces are still in kN in the array. So I have to go to  Tools>Project Preferences>Units>Force and quit, and then the array is updated and forces appear in daN.
So there is a kind of "refresh" problem for units.
Same problem if I want to diplay forces diagrams. Unless I open Tools>Project Preferences>Units>Force, forces are still in kN.
How can I fix this ?
Product Support
Rafal.Gaweda
12-23-2012 11:32 PM in reply to: guillaumeniel
That's interesting, we have to check it.
Rafal Gaweda
Active Contributor
guillaumeniel
01-13-2013 06:01 AM in reply to: Rafal.Gaweda
Any answer to my problem ?
Product Support
Artur.Kosakowski
01-13-2013 11:17 PM in reply to: guillaumeniel
It will not be possible for us to investigate this situation before the next week.
Try to add projPref.Units.Refresh at the end of your code.
Artur Kosakowski
