I would like to create cladding panels (I will use them to apply area load to my structure) in Robot 2014 through API using node numbers to define the triangular panels. I have seen in another thread an example of how to create panels with API, but I see that they use coordinates.
I would like to define the panels with node numbers (the same way to define bars), in order for the panels to 'move' with my structure, when I change the node's coordinates (I am doing an optimisation based on the node's location). Is that possible?
When I try to create a panel that way through the GUI, it seems only possible if you have bars that enclose an area, but in my case, I don't have such bars.
Thanks in advance!
V.
Solved by Rafal.Gaweda. Go to Solution.
Is that possible?
Unfortunately not.
Only corrdinates can be used.
