Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Robot API compatibility
3 REPLIES 3
W2K
237 Views, 3 Replies
I am creating a small application using Robot API. It has to work with at lest Robot 2012 and all future versions(currently 2014).
Currentyl I am using Robot API v14. Will it work on version 2012-2015 and future versions or I need to recompile the code for every version of robot adding dependencies for correct version of API ?
Another thing. Does the user need to istall anything to use application that uses Robot API or it is enouuh to have Robot installed ?
3 REPLIES 3
Rafal.Gaweda
in reply to: W2K
No.
It depends how Project is made \ configured.
If you look at References \ RobotOM -> Properties and see Embed = True -> no need to install anything extra
If you look at References \ RobotOM -> Properties and see Embed = False-> Interop.RobotOM.dll should be located in the same folder where your project dll \ exe will be installd \ copied
Rafal Gaweda
W2K
in reply to: Rafal.Gaweda
For the first question: "No" means that it won't  work in other versions than compiled ?
Rafal.Gaweda
Yes
No.
Rafal Gaweda
