Discussion Groups
Robot Structural Analysis
Active Contributor
medtayeb
Robot-API BeamsColor
228 Views, 3 Replies
09-25-2012 04:38 AM
I used  IRobotView2 to see a structure.
The application goes through every level,then for each level identifies and tests each beam.
how to color the ( current ) beam to be  tested.
Thanks.
Please use plain text.
Product Support
Rafal.Gaweda
Re: Robot-API BeamsColor
09-25-2012 05:02 AM in reply to: medtayeb
Make selection ? Should be in red.
Rafal Gaweda
Active Contributor
medtayeb
09-25-2012 07:29 AM in reply to: medtayeb
Hi
I tried that but no selection appears on  view    ( IRobotView2 MyStrView )
IRobotSelection MyBarSelected = MyStrView.Selection.Get(IRobotObjectType.I_OT_BAR);
for (num_bar = 1; num_bar <= MyBarSelected.Count; num_bar++)
                    MyBarSelected.Get(num_bar);
Many thanks for help.
Product Support
Rafal.Gaweda
10-11-2012 12:53 AM in reply to: medtayeb
example code :
Dim sObj As RobotSelection
Set sObj = RobApp.Project.Structure.Selections.Get(I_OT_BAR) Dim sObj1 As RobotSelection Set sObj1 = RobApp.Project.Structure.Selections.Create(I_OT_BAR) If ((Not sObj Is Nothing) And (Not sObj1 Is Nothing)) Then sObj1.FromText ("3") sObj.Add sObj1 End If
Rafal Gaweda
