Hello everybody,
Accidentally I have a problem with steel design calculation dialogue window - it hasn't some buttons and text boxes. Problem is shown on image named Problem.png and normal state of this window is shown on image Normal.png.
RSA version is 2015, trial and it happens on both Russian steel codes - SNiP II-23-81 and SP 16.13330.2011.
I have deleted files from CfgUsr and without any luck.
Have you some ideas about this problem?
Solved by Artur.Kosakowski. Go to Solution.
Hi Igor!
I had the same issue. Try to switch to English UI and after that return to Russian one. Also try to delete all steel codes from the list of codes and then add them again.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Hi Igor!
Hi, Roman!
Thank you for your help, but I've tried and it didn't work.
I can't see any such issue on my PC. Have you got SP1 for Robot 2015 installed?
Hello, Artur,
Thank you for your help!. Installation of SP1 for RSA 2015 solved this problem. Hopefully, it won't happen again !
