Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Robot 2015 not running steel design
3 REPLIES 3
i.franco
328 Views, 3 Replies
Good day.
I'm currently designing a tower for a compressed air duct. I just switched from 2014 version to 2015 version of the software, but I've encountered an issue since I cannot run the steel design-verification for my structure. When I click calculations, the program just freezes and does not calculate anything, and then it crashes without any change.
Is there a compatibility problem between 2014 and 2015 versions? If so, how do I fix it?
The model is attatched to this message.
Thank you for your assistance.
3 REPLIES 3
Yes, this was an old issue, it depend by the auto stiffener position definition in buckling length evaluation. You have two way to solve this issue:
1) install all the service packs and hotfixes for arsa 2015;
2) check the assignation of code checking parameters, make sure that you don't assign the auto slenderness definition to bars that not have intermediate constraints.
Hope I help you, greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Try to install SP2 for Robot 2015. I can't see any issue with running code checking for Robot 2015 SP2 on my computer.
Artur Kosakowski
i.franco
in reply to: Artur.Kosakowski
Thank you, the service pack solved the issue.
Ivan Franco
