Good day.
I'm currently designing a tower for a compressed air duct. I just switched from 2014 version to 2015 version of the software, but I've encountered an issue since I cannot run the steel design-verification for my structure. When I click calculations, the program just freezes and does not calculate anything, and then it crashes without any change.
Is there a compatibility problem between 2014 and 2015 versions? If so, how do I fix it?
The model is attatched to this message.
Thank you for your assistance.
Solved by Artur.Kosakowski. Go to Solution.
Solved by StefanoPasquini6790. Go to Solution.
Yes, this was an old issue, it depend by the auto stiffener position definition in buckling length evaluation. You have two way to solve this issue:
1) install all the service packs and hotfixes for arsa 2015;
2) check the assignation of code checking parameters, make sure that you don't assign the auto slenderness definition to bars that not have intermediate constraints.
Hope I help you, greetings
Try to install SP2 for Robot 2015. I can't see any issue with running code checking for Robot 2015 SP2 on my computer.
