Post edited: the link has been deleted. See the message 5 below.
Artur
Thank you for link, but impossible to connect and to get trial
The trial version should be available in a standard way on Autodesk sites (replacing v.2012) soon. As unfortunately the link I provided seems to be inaccessible for you I will delete it to avoid any additional issues with it. I will update this topic when the change I mentioned above has been done.
No, there is not. What kind of the details in particular you would like to know (the obvious answer ALL is ruled out as not possible to handle but I try to help to the point I'm able to )
The link to the 2013 trial version
http://usa.autodesk.com/robot-structural-analysis-professional/
