Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Robot 2013 Component Manager: "Error while creating robot registry key."
2 REPLIES 2
544 Views, 2 Replies
When I try to run Robot 2013 Pro Component Manager, I recieve an error message that says "Error while creating robot registry key." If I right-click it and choose "Run as Administrator," I do not get an error message but nothing happens after that. I'm using Windows 7 64-bit and this problem is happening on multiple computers. I'd appreciate any help; thanks!
2 REPLIES 2
Artur.Kosakowski
Assuming you mean the component registration then there should be no visible effect. Form your description I think that the registration was done correctly when run in as Administator. This registration is done during the program installation and usually there is no need to run it again manually. Any particular reason for this?
Artur Kosakowski
Sorry, I'm not familiar with how Robot actually works; I'm just tasked with installing it in a computer lab, so I ran anything that said "Robot" in the Start menu to make sure that it ran ok. Thanks for your help!
