I am trying to generate the mesh for a complex structure with panels, and I don't know if Robot is running it or has it crashed. I get a (Not Responding) message at the top of my screen. This usually happens when it is running something complex. However after 26 hours generating the model....I am losing hope.
Help Help!
Could you please attach the file?
It needs to be analyse.
Thank in advance
Regards
Hi Chazal,
Could you find my robot model at link below?
I meet the same problem.
1. Delete all meshes
2. Assign correct meshing parameters to all panels:
3. Mesh walls first
4. Mesh slabs then
5. Run Model Correction with tolerance =1cm
6. Run Model Generation or Calculations
Hi Rafa.
Thank you very much for your support. Could you let me know forcing ratio mean?
