I'm modelling the next structure and I would like to put an internal mass in its center of gravity. For this, i would like to connect this mass with the structure through rigid links, but the problem is that Robot makes a connection outside of the structure.
I have thought in doing several parts in the structure (several centers of gravity and several nodal masters),so I could reduce the error, but could I fix the problem without doing this?
Thanks a lot
Solved by Artur.Kosakowski. Go to Solution.
Try to switch off display of rigid link surface.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
thanks for your answer. I thought the problem was solved, but know I hesitate because if I'm right, if we switch off display of rigid link surface, we will not see anymore the "outside" connection, but it will still be there. ROBOT takes it for the calculation, and so, even if we don't see it, the result of the calculation will be the same, isn't?
Thanks in advance
No, the surface is sort of the 'enhanced' display intended more for object like slabs when you don't want to see too much of details (lines to each node of the slab). The display I suggested is the exact one.
Good morning ,
I am using rigid link to model behavior of a frame structure due a seismic lateral equivalence force ,
All nodes are linked to a master node located at he mass center of gravity.
To correct simulate behavior all directions are supossed to be Blocked Ux , Uy , Yz and only rotation shoul be unblocked ?
Could you correct my supposition if is wrong
Best Regards
What do you intend to model with these rigid links? A slab?
what I am to inted to model is a ground mounted structure for a Photovoltaic Panel Array
Thank you for the quick response
Could you attach a sketch of this structure and the intended location of the rigid links?
Herein the screenshot of the struture
Thank you very much for the support
RRA
You may want to define a panel with the predefined rigid diaphragm calculation model or define UZ RX RY support and the rigid links as shown below.
