Discussion Groups
Robot Structural Analysis
Active Member
jaredvh
Rigid Link (Blocked Directions)???
504 Views, 13 Replies
11-28-2012 03:44 PM
I am using rigid links on a structure to simulate lifting lugs on the perimeter of the structure.  When creating the rigid link there is an option to specify "Blocked Directions" there are checkboxes for UX, UY, UZ, RX, RY and RZ. Would somebody be able to explain to me what RSA means by these "Blocked Directions"?
Also, Which node do you select as the Master/ Slave when creating these rigid links? And is there a way to delete a rigid link if you no longer wish to use it?
Thank you,
Jared
Please use plain text.
Product Support
Artur.Kosakowski
Re: Rigid Link (Blocked Directions)???
11-28-2012 11:44 PM in reply to: jaredvh
Please check:
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-88C4C842-5D90-4E85-8F8C-D47D6E474E29.htm
Artur Kosakowski
Khristopherson
02-19-2014 12:43 PM in reply to: jaredvh
Hello. I set some rigid links in my model, but i dont know how to delete them. I put a rigid link in a wrong place and i want to eliminate it but i just cand find where or how to do it. I search for threads on this topic but there was none.
Thank you.
Khristopherson
02-19-2014 12:50 PM in reply to: Khristopherson
This is a picture of how i see the rigid link after erasing one of the nodes.
Product Support
Artur.Kosakowski
02-20-2014 12:21 AM in reply to: Khristopherson
Either http://forums.autodesk.com/t5/Robot-Structural-Analysis/Lines-in-model-space/m-p/4542061#M18058
or
Artur Kosakowski
Khristopherson
02-20-2014 08:18 AM in reply to: Artur.Kosakowski
Thank you.
I have another question about rigid links. When i verificate my model sometimes it gives me warnings about isolated nodes, and when i check to see which nodes are they, they always are the nodes that I use to place the rigid links between 2 bars. Is it normal?
Thanks again for your help.
Product Support
Artur.Kosakowski
02-20-2014 08:20 AM in reply to: Khristopherson
Attach a sample file with such situation please.
Artur Kosakowski
Khristopherson
02-20-2014 08:36 AM in reply to: Artur.Kosakowski
It does not happen every time. In this moment it happens only at node 1540, it is what the verification says.
And when i run it, now i get inestability type 3 in node 1383. I really don not know why this happen. I made the calculations like 15min ago and did not get any inestability nor warning of isolated nodes. They seem to appear out of nowhere. I was to attach the file. But its size is a bit larger than it is accepted here in the forum, is there any other way i can send it to you?
Hope you can help me.
Thank you.
Khristopherson
02-20-2014 08:38 AM in reply to: Artur.Kosakowski
Product Support
Artur.Kosakowski
02-21-2014 06:23 AM in reply to: Khristopherson
Error (404)
Artur Kosakowski
