I am trying to connect Revit 2014 to Robot 2014 for simple frame anaysis, however there is no link to perform analysis. There is only one link for Reinforcement code checks as shown in the attached screen. Also my Robot 2014 does not have the integration link to Revit 2014 but Robot 2015 has a link but does not connect.
Kindly help with guidance on how to get the link for structural analysis.
Best regards,
Aliyu A. Aziz
Solved by AhmedZA. Go to Solution.
just suggestion
uninstall toolkit and try to install Structural Analysis Toolkit 2014 may be you are using the Previous Versions of toolkit
https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3Astructura...
Dear Ahmed,
Thanks for the suggestion and the link. Installing the toolkit resolved the issues from Revit side. On the Robot 2014 side, I still don't have a link in the Add-Ins for transfer to Revit.
Kindly assist.
Best regards,
Aliyu A. Aziz
