I would like to clean all data in Revit that were imported from Robot: member numbers, advanced bar properties, load combinations, member types, etc. How to do it? This is for troubleshooting.
Solved by Artur.Kosakowski. Go to Solution.
Explain me more precesily what does it mean, what does not run , any error, effect ...?
REX Cleaner 2014:
all files from zip should be copied to:
"c:\Program Files\Common Files\Autodesk Shared\Extensions 2014\Modules\Tools\DREXProjectCleaner"
than:
Now the files are copied where they should be, but I am experiencing the same problem as with the 2013 version. When I click it, it does not seem to run at all. See this video: http://screencast.com/t/kWQ4KvPmdt6
I tried to run it on a different machine and there it works. I am confused how to use it though. The only thing I can really do is to open a file, but it asks me to select and an .rxd file. What is this, where do I find it?
Patrick,
PLease check this one.
It still does not work. The icon is added to the ribbon, but after I click it, nothing happens.
ONly on this one computer I guess.
We need to access it remotely to check it.
I will contact you tomorrow.
Is there any update for the cleaner addin? I'd like to use the tool but I got stuck as did PatrickEC. I need to remove the attached data from the revit model. I tried the addin with two different computers without sucess.. thanks.
