Discussion Groups
Robot Structural Analysis
New Member
teresa
Revit model to Robot Analysis program
287 Views, 5 Replies
10-23-2012 08:33 AM
We have import a RC structure model from Revit.  However, we are experiencing some issues, below are our queries:
  1. BEAM POSITION:
Firstly, we have tried entering the RC beams using different settings in Revit before exporting the information (i.e. We have set beams at same levels as top of slab, centre and bottom of slab).  However, when we import the model into Robot, in all scenario, the centre of the beams are imported as if they are at the centre of the slab.
I understand we have an offsets option to fix this (Geometry - Additional Attributes - Offsets).  However, can you confirm is this a bug in the software or are there any ways to put in the correct beam levels when we exporting the model??
2. CONNECTION BETWEEN BEAM AND SLAB:
Secondly, how can you ensure the structural elements (i.e. beam and slab) are joined properly in Robot?  The beams seems to acting on its own (i.e. not connected to the slab properly) in the analysis results from the model.  We have used the JOIN options in Revit before exporting and it seems to be connected before exporting.  We have also ensure the beam starting at the correct node.
3. LOCAL THICKENING
Is there a way to enter local thickening (i.e. instead of entering as a beam) to the slab?  If so, can you tell us how to do that?
Appreciate if you could help us out on the above.  Thanks!
Teresa
Please use plain text.
Product Support
Rafal.Gaweda
Re: Revit model to Robot Analysis program
10-23-2012 11:22 PM in reply to: teresa
Please send us Revit model to check.
(Keep in mind that robot imports analytical lines so check analytical lines locations in Revit model)
Rafal Gaweda
Product Support
Artur.Kosakowski
10-23-2012 11:43 PM in reply to: teresa
3. LOCAL THICKENING
Please check:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Column-head/m-p/3511404/
Artur Kosakowski
New Member
teresa
10-24-2012 04:31 AM in reply to: Rafal.Gaweda
Can you confirm your email address please?  Many thanks!
Product Support
Rafal.Gaweda
10-25-2012 12:29 AM in reply to: teresa
Rafal Gaweda
Product Support
Rafal.Gaweda
10-25-2012 02:01 AM in reply to: teresa
You are right, due to inaccuracies in model I suggest to enlarge model generation tolerance
Rafal Gaweda
