Hi!
I have a problem. When I try to send a model from Revit to Robot, it dosn't work. All stops at this stage (creation of the model) and dosn't go beyond:
When I choose in integration options "Use the RTD file" and try to update the model - update works.
A few days ago all the options work on my computer...
What can be the reason?
Denis
I do not see any problems http://screencast.com/t/UQBpwzyEhFp
Keep in mind you should uase Revit 2014 and Robot 2014.
Try to register robot before next robot start - menu start windows \ All Programs \ Autodesk \ Autodesk Robot.... \ Tools \ Autodesk Robot Structural Analysis Professional - Component Registration
Thanks for the response, Rafal!
My workflow looks like follows: http://screencast.com/t/EmbpURTi
I have registered Robot components by your advice. Unfortunately, there is no effect. (I have Revit 2014 and Robot 2014).
check whether robot.exe process is not running \ hanging . Kill it then try.
It didn't help(
The last thing I tried to do - I renamed the folder CfgUsr in Appdata (C:\Users\User name\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2014). It helped. Now export from Revit works. Cause remains unclear..
But window about the processing is hanging all the time:
http://screencast.com/t/5mjEdTTw
In the Task manager the following picture:http://screencast.com/t/ra4KNNUbe5e.
Denis
Yes, it pleases.
I am very appreciate for your suggestions, Rafal. Thanks!
