Hi guys,
I'm trying to import member forces and reactions from Robot into Revit (both version 2012).
Is this functionality supported in Revit? ie I want to be able to click on a beam in Revit and see the internal forces from the Robot analysis. (reactions at supports too)
Rafal I'm thinking you must know of a way to do this via API if it can't be supported natively through the interface. I could for example dump forces into excel and then pull them back into Revit somehow (to be appended to a beam tag for example??)
Cheers,
Tony.
Solved by Rafal.Gaweda. Go to Solution.
Not that easy but bar end forces can be displayed: http://screencast.com/t/aPIUOjodwBkR
Unfortunatelly moment values are wrong in this approach. It is planned to be corrected in SP1 for ARSA 2013
For now not possible
I think it should not be a problem to do it this way by RST API
From clouds:
