Discussion Groups
Robot Structural Analysis
bartosz_borowiak
Accepted Solution
Revit -> Robot model corection problem
243 Views, 15 Replies
02-26-2014 01:20 AM
I am working with Robot model gathered from Revit. Unrotunately I don't have acces to Revit model to correct it before sending to Robot. I cleared most of inaccuracies but still it takes ages to generate computinal model and than analyise it. I will be very grateful for any guideline how to deal with it and make model lighter.
Bartosz Borowiak
Link to model file: http://www.filemail.com/d/ganmmgvhbpkklju
Please use plain text.
Product Support
Rafal.Gaweda
Re: Revit -> Robot model corection problem
02-26-2014 01:47 AM in reply to: bartosz_borowiak
Did you?
What about unmeshed panels? What abot concertation of meshes -> something wrong with geometry.
Search forum for topics about model correction, inaccuracies, meshing
HInts: do not use regular mesh, do not use kinematic links, for this model I recommend min 1m mesh, try to mesh walls first then the rest.
Rafal Gaweda
Product Support
Rafal.Gaweda
02-26-2014 07:04 AM in reply to: Rafal.Gaweda
To start - use this model: http://we.tl/tJJFt78jlb
Some walls geometry is corrected but....
The rest must be done by you - either correct only meshes or geometry and meshes
Rafal Gaweda
bartosz_borowiak
02-26-2014 09:57 AM in reply to: bartosz_borowiak
Witaj Rafal, Thank you for that model but,
In the meantime I did corrected geometry and applied preferences about generating mesh. Still having problem to analysis it with selfweight. It's my first time working with revit exprted model and I'm getting my nerves with it.
Attached  model:
http://www.filemail.com/d/ofawbuyxbebbxqo
Kind regards
Bartek
Product Support
Rafal.Gaweda
02-27-2014 02:57 AM in reply to: bartosz_borowiak
Why didn't you correct my ~30000 nodes model?
If you want to use yours - 371000 nodes - your choice but you need to have 12+ GB RAM memory and time.
Rafal Gaweda
bartosz_borowiak
02-27-2014 04:00 AM in reply to: bartosz_borowiak
In th emeantime I was correcting my geometry and I thought that will be better model. I will corect yours with less node and we will se what will happen. Thank you
Product Support
Rafal.Gaweda
02-27-2014 04:03 AM in reply to: bartosz_borowiak
30-40 thousand node model is OK for this structure.
Go in this direction.
Rafal Gaweda
bartosz_borowiak
02-27-2014 08:46 AM in reply to: bartosz_borowiak
Thank you for that hint. In fact it was so much easier and quicker working on that "light" version of model with less nodes. My corrected model attached below, still with some meshing problems. Thank in advance for help.
http://www.4shared.com/zip/ms_QGSOece/JLP_BB.html
bartosz_borowiak
02-27-2014 09:29 AM in reply to: bartosz_borowiak
I'm aware that those are locations of the meshing problem but can't really figure out how it can be even better corrected.
Product Support
Rafal.Gaweda
02-28-2014 12:14 AM in reply to: bartosz_borowiak
File please
Rafal Gaweda
