Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 17
MUHANNAD.ABU_ABDO
2852 Views, 16 Replies
Retaining wall
how i can model the retaining wall by using RSA 2014 .. is someone give me an example ??
Muhannad M.Abu Abdo
Structural Design Engineer
Tags (1)
16 REPLIES 16
Message 2 of 17
Very open question?  Smiley Sad
Which part do you need to model?   Wall, footing, or both?  What conditions for support, what loads?
Message 3 of 17
i want both of them ( wall & footing ) .. also surcharge load , active pressure on stem and passive pressure on toe
that's all ... thanks a lot
Muhannad M.Abu Abdo
Message 4 of 17
Have you made an attempt yet?
Show what you have tried.
It's a two way road.......
Message 5 of 17
okay i will
Muhannad M.Abu Abdo
Message 6 of 17
i tired to model it as solid .. i don't know if this is right or wrong ..
Muhannad M.Abu Abdo
Message 7 of 17
wouldn't do it with a solid.  Two plates will work .
Message 8 of 17
can you show me how ?  and assign the load on it .. ! thanks sir
Muhannad M.Abu Abdo
Tags (1)
Message 9 of 17
bjur
in reply to: MUHANNAD.ABU_ABDO
I do it all the time. I'll upload a file Monday. Basically you model both wall and footing as panels. The footing panel has a horizontal planer reaction set along with soil reaction properties set. The loading on the wall is standard. The analysis is run as nonlinear due to the soil springs assigned to the footing.
Message 10 of 17
MUHANNAD.ABU_ABDO
in reply to: bjur
oh great dear .. thanks a lot .. i'm waiting
Muhannad M.Abu Abdo
Message 11 of 17
bjur
See attached.
Message 12 of 17
MUHANNAD.ABU_ABDO
in reply to: bjur
oh that's great dear .. but if you can show me by video or photos to more accurate understanding
Muhannad M.Abu Abdo
Message 13 of 17
Why not just give your design parameters to Bjur, he can model it for you no?
Robot Frustrated
Message 14 of 17
i'm really want to know how can make this type of modeling .. i'm in problem i'm not joking .. if you want to help me i'm grateful to you
Muhannad M.Abu Abdo
Message 15 of 17
saclovitzky
in reply to: bjur
why do you need to run it as non-linear analysis?Is the standard analysis not enough to capture the result?
Message 16 of 17
bjur
Because the back of the wall footing may not have soil bearing (no tension on dirt). Need to run as nonlinear to remove reactions at any uplift areas.
Message 17 of 17
saclovitzky
in reply to: bjur
Thanks Bjur, can you possibly look at my ret. wall model if it is done correctly(pls. see attached).
