how i can model the retaining wall by using RSA 2014 .. is someone give me an example ??
Very open question?
Which part do you need to model? Wall, footing, or both? What conditions for support, what loads?
i want both of them ( wall & footing ) .. also surcharge load , active pressure on stem and passive pressure on toe
that's all ... thanks a lot
Have you made an attempt yet?
Show what you have tried.
It's a two way road.......
i tired to model it as solid .. i don't know if this is right or wrong ..
can you show me how ? and assign the load on it .. ! thanks sir
oh great dear .. thanks a lot .. i'm waiting
oh that's great dear .. but if you can show me by video or photos to more accurate understanding
Why not just give your design parameters to Bjur, he can model it for you no?
i'm really want to know how can make this type of modeling .. i'm in problem i'm not joking .. if you want to help me i'm grateful to you
why do you need to run it as non-linear analysis?Is the standard analysis not enough to capture the result?
Thanks Bjur, can you possibly look at my ret. wall model if it is done correctly(pls. see attached).
