Robot Structural Analysis
Valued Contributor
mortel09
results
260 Views, 3 Replies
01-31-2012 02:32 AM
Hello. I was woundering on what i should do after i have calculated my construction... How can i know if the construction can handle the loads that are on it? Its a easy 3D frame construction...
Please use plain text.
Product Support
Artur.Kosakowski
Re: results
01-31-2012 02:45 AM in reply to: mortel09
Please try to use the design modules that are incorporate in the program. In fact this is what they are intended for in the first place :smileyhappy:
Artur Kosakowski
Valued Contributor
mortel09
Re: results
01-31-2012 02:59 AM in reply to: Artur.Kosakowski
could you give you us a detalied step by step of how you can easly find out if the constructions holds?
Product Support
Artur.Kosakowski
Re: results
01-31-2012 03:16 AM in reply to: mortel09
Please refer to the 3rd message from this topic of the forum:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Tutorials-for-Robot-Structure-analysis/m-p/2...
The description of the steel design can be found in chapters 2.7, 5.5 and 6.4 of the training manual.
Artur Kosakowski
