Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
RESULTS - DISPLACEMENT vs. DEFLECTION - Definitions used by Robot
5 REPLIES 5
7127 Views, 5 Replies
What are the definitions for deflection and displacement used in Autodesk Robot Structural Analysis ?
5 REPLIES 5
Artur.Kosakowski
Which kind of results do you mean exactly? Could you make a screen capture that illustrates what you want to compare please?
Artur Kosakowski
in reply to: Artur.Kosakowski
I don't want to compare any results I just want to know what are the differences between deflection and displacement ? I want definitions for both deflection and displacement used by Autodesk Robot Structural Analysis.
Thanks.
Artur.Kosakowski
Artur Kosakowski
Does this illustration of deflection and displacement apply to a 3D frame ? Is there any sentence that defines deflection and displacement ?
Thanks.
Artur.Kosakowski
Yes, it does. The displacements is the distance from the original position of a point to its final location on the deformed model. The deflection is the distance from the line that links the origin and end nodes of a bar on the deformed model with the position of a point on the deformed model.
Artur Kosakowski
