What are the definitions for deflection and displacement used in Autodesk Robot Structural Analysis ?
Solved by Artur.Kosakowski. Go to Solution.
Which kind of results do you mean exactly? Could you make a screen capture that illustrates what you want to compare please?
I don't want to compare any results I just want to know what are the differences between deflection and displacement ? I want definitions for both deflection and displacement used by Autodesk Robot Structural Analysis.
Thanks.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Does this illustration of deflection and displacement apply to a 3D frame ? Is there any sentence that defines deflection and displacement ?
Thanks.
Yes, it does. The displacements is the distance from the original position of a point to its final location on the deformed model. The deflection is the distance from the line that links the origin and end nodes of a bar on the deformed model with the position of a point on the deformed model.
