Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Residual mode by API
9 REPLIES 9
Message 1 of 10
faisal.aaouatif
988 Views, 9 Replies
Good morning / Good evening ;
I would like to know how to access the flag indication the use or not of a residual mode for a given seismic case by using API.
and by the way , auxilliary data ( Last calculated mode , limite frequency  , augmentation factor )
Thank you
9 REPLIES 9
Message 2 of 10
Which seismic code do you mean?
Artur Kosakowski
Message 3 of 10
RPS2000 ( Morocco ).
Thank you
Message 4 of 10
This option is currently not available in API. I have added it to the wish list.
Artur Kosakowski
Message 5 of 10
Ok
Thank you very much
Message 6 of 10
I have made a modal analysis for a five story reinforced concrete building based on the UBC97 code
The mass participation for X & Y directions is about 73% and the frequency is about 33 (no significant change in these results from mode number 30 to mode number 40)
I have read that for such case residual mode should be used for seismic analysis, I have tried but I did not know how to do it
Thank you for help
Message 7 of 10
Simau
in reply to: aimanalaawar
It seems, this feature is not RSA for UBC 97
Window for EC8 regulation
Window for UBC 97
M. Agayr
Message 8 of 10
aimanalaawar
in reply to: Simau
Okay, any idea what to do in such a case as I mentioned (mass participation 73 and frequency 33)
Message 9 of 10
Simau
in reply to: faisal.aaouatif
The remaing masses may be located in very stiff portion of the structure.
Can you post your strcture or model.
M. Agayr
Message 10 of 10
Hi @faisal.aaouatif
You should use the spectral analysis you can define there the spectrum as per UBC then include residual mode.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
