How is possible reset the view paramterers?
I changed the thema some time ago and now I'm not able to get the original parameters.
I'm going crazy! please help me!
Solved by Romanich. Go to Solution.
Dear Rafal,
Thanks for your fast answer
I moved the file away but the colors do not change. Probably I not explained well the problem: I would like reset to the original the screen colors (nodes colors, rigid plane colors.. etc. etc..)
Ciao Marco,
Maybe this option will help you:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Hasn't helped me - using 2017 version.
Any further suggestions?
HI @34987816659
Try to rename c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2017\CfgUsr folder
