REQUIRED REINFORCEMENT
5 REPLIES 5
AJA14
447 Views, 5 Replies
I am a little bit confused at to what is happening with calculating required ties for columns. If you look at the image, I have set my tie diameters to T10 with 2 legs in the first table, and T20 with 6 legs in the second table, however, the required spacing remained 12.6 cm for first bar in both cases and 32.6 cm for the second bar in both cases as well. I even checked the applied shear forces and they are almost the same needless to say almost negligible when it comes to a 300 by 700 column with an f'c of 40 MPa. I even changed the f'c to 10 MPa but the only thing that changed was the longintudinal reinforcement. Any ideas.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
5 REPLIES 5
Rafal.Gaweda
in reply to: AJA14
PLease send us model to check.
Rafal Gaweda
AJA14
in reply to: Rafal.Gaweda
Please find the model attached.
Ali Al-Hammoud
AJA14
in reply to: AJA14
I forgot to mention, it is a .zip file. Regards.
Ali Al-Hammoud
Rafal.Gaweda
in reply to: AJA14
It seems RC column section 70x30 is not the same for design as 30x70. Developers will check the code.
So if RC Column section is considered as bxh then b must be smaller than h (b<h).
PLease use 30x70 and rotate it by gamma angle.
Rafal Gaweda
Artur.Kosakowski
in reply to: AJA14
Robot 2015 SP3
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
