Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Required reinforcement map only shows black color
5 REPLIES 5
641 Views, 5 Replies
I got some extreme values in my provided reinforcement map and want to take a look at the required reinforcement map to see if I can ignore these values. But the map has only black color and it is impossible to read the values. Is it a way that I can make Robot showing me the more colors? See also the picture.
5 REPLIES 5
Artur.Kosakowski
What happens if you delete the slab from the RC mode of the Inspector and import it again from the model?
Artur Kosakowski
in reply to: Artur.Kosakowski
That helped, but when I run calculations, and take a look at provided reinforcement and then go back to reinforcement map for FE results, it`s all black again.
Med vennlig hilsen
________________________________
Eirik Nordvik
Sivilingeni?r konstruksjonsteknikk
Byggeteknikk
Telefon
Mobil +47 90911657
Eirik.Nordvik@sweco.no
Sweco Norge AS
Bomveien 13
NO-7725 Steinkjer
Telefonnummer +47 74 160750
www.sweco.no
[cid:image001.jpg@01CF31B2.05EE8090]
Please consider the environment before printing this e-mail.
Artur.Kosakowski
Could you attach the model and list the steps to follow please? Thank you.
Artur Kosakowski
Send you the file through filemail.com.
Med vennlig hilsen
Eirik Nordvik
Byggeteknikk
Telefon
Mobil +47 90911657
Sweco Norge AS
Bomveien 13
NO-7725 Steinkjer
www.sweco.no
[cid:image001.jpg@01CF3262.803981F0]
Artur.Kosakowski
I followed the steps you described but in my case all looks fine. I will send you the details how to download 'my' file in a separate message. Please check if you can see the map correctly.
Artur Kosakowski
