Discussion Groups
Robot Structural Analysis
Active Contributor
1 Kudo
Required reinforcement map only shows black color
158 Views, 5 Replies
02-23-2014 09:19 AM
I got some extreme values in my provided reinforcement map and want to take a look at the required reinforcement map to see if I can ignore these values. But the map has only black color and it is impossible to read the values. Is it a way that I can make Robot showing me the more colors? See also the picture.
Product Support
760 Kudos
Re: Required reinforcement map only shows black color
02-24-2014 04:00 AM in reply to: eiriknor
What happens if you delete the slab from the RC mode of the Inspector and import it again from the model?
Artur Kosakowski
Active Contributor
1 Kudo
02-24-2014 01:45 PM in reply to: Artur.Kosakowski
That helped, but when I run calculations, and take a look at provided reinforcement and then go back to reinforcement map for FE results, it`s all black again.
Med vennlig hilsen
________________________________
Eirik Nordvik
Sivilingeni?r konstruksjonsteknikk
Byggeteknikk
Telefon
Mobil +47 90911657
Eirik.Nordvik@sweco.no
Sweco Norge AS
Bomveien 13
NO-7725 Steinkjer
Telefonnummer +47 74 160750
www.sweco.no
[cid:image001.jpg@01CF31B2.05EE8090]
Please consider the environment before printing this e-mail.
Product Support
760 Kudos
02-25-2014 01:06 AM in reply to: eiriknor
Could you attach the model and list the steps to follow please? Thank you.
Artur Kosakowski
Active Contributor
1 Kudo
02-25-2014 10:48 AM in reply to: Artur.Kosakowski
Send you the file through filemail.com.
Med vennlig hilsen
Eirik Nordvik
Byggeteknikk
Telefon
Mobil +47 90911657
Sweco Norge AS
Bomveien 13
NO-7725 Steinkjer
www.sweco.no
[cid:image001.jpg@01CF3262.803981F0]
Product Support
760 Kudos
02-26-2014 08:04 AM in reply to: eiriknor
I followed the steps you described but in my case all looks fine. I will send you the details how to download 'my' file in a separate message. Please check if you can see the map correctly.
Artur Kosakowski
