Discussion Groups
Robot Structural Analysis
stroxy
Accepted Solution
Required Reinforcement different from Provided Reinforcement
350 Views, 3 Replies
12-23-2011 04:25 AM
I am noticing that the forces (and hence reinforcement calc results) are different in the required reinforcement module and provided reinforcement module.  Is there a reason for this.  I have attached snapshots showing forces used in the2 modules for bar 396 (highlighted in red in the required reinforcement module).
Please use plain text.
Product Support
Rafal.Gaweda
Re: Required Reinforcement different from Provided Reinforcement
12-23-2011 06:00 AM in reply to: stroxy
Hi
Have you selected the same combinations for both design?
As far as I can see you are comparing different combination results
Rafal Gaweda
stroxy
12-23-2011 09:56 AM in reply to: Rafal.Gaweda
I chose my combinations as attached
Product Support
Artur.Kosakowski
12-27-2011 11:25 PM in reply to: stroxy
Stroxy,
Two points:
1. Actually your selection of loads for these two methods seems to be different. I assume that you selected manual or code combinations for the RC member theoretical reinforcement module and simple load cases for the RC Column design module. The latter results in allowing the program to create combinations itself based on the rules (regulation) you selected in Job Preferences.
2. Mind that the load/combination indicated as the governing one is the one that give the highest load/capacity ratio. As in the RC Column design module calculations of the column's capacity is done by checking the equilibrium of applied forces vs. generated reinforcement taking into account the exact position of each of the reinforcement bar rather than theoretical area of reinforcement it may happen that these two modules show different governing load case if the column capacity against each of them is similar.
Artur Kosakowski
