Hi everyone,
Is there a way to renumber some selected points without using the geometry/numbering tool ?
My problem is that I can't use the automatic geometrical tool because the numbers have no geometrical logic so i have to do it one by one.
The model is now complete (3000 nodes / 5000 bars), I have only 46 nodes to renumber (the supports actually), maybe they are used elsewhere in the structure, I know I should have done it since the beginning but .... for one node it take around 3mn .... so if someone could make I spare 1h30 unsing table, api whatever, I'll be glad!
TS
Solved by t.sautierr. Go to Solution.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
??? Last Time it was so long ... sorry for the disturbance then. It's true I didn't try for some days.
I just used the same.. But I think I am doing something wrong which are interrupting the procedure.
