Removing generated FE nodes?
1 REPLY 1
1212 Views, 1 Reply
Hi There,
Apologies in advance if this is an obvious question -
The image attached originally consisted of 3 wall panels made from 8 corner nodes. After analysing I can't seem to find a way of physically removing the FE generated nodes and cleaning back to the original nodes. Is this possible?
The reason behind this is so that I can adjust the original (not generated) node positions, and add a couple of new nodes / wall/beam elements.
1 REPLY 1
bjur
See attached picture.  There is a remove mesh button.
