I ran a wind simulation for load case 5 and when I have case 5 selected the pressure is shown. I have since removed the wind loads from this case in the loads table and defined the wind loads "by hand". The contour plot of the pressure on elements is still showing. How can I get rid of the contour plot?
Solved by Artur.Kosakowski. Go to Solution.
Hey. I isolated my map to a Case and deleted the entire case from my load table. Once I added the load back with the same name and case number, the map was no longer there.
