Hi Artur
Can you take a look in this example I become a very high reinforcement ratio
attached you will find the croped file as a substructure and the final bema drawings
Best regards
Marcelo
Hi Rafal
Thank you for your quick reply
It must be something with the safety parameters, because the results are over 500% greater than required
I hope you will fix soon.
Best regards
Marcelo
Not that simple.
@Rafal.Gaweda wrote:It must be something with the safety parameters, because the results are over 500% greater than required
Not that simple.
I guess that will take a while to be fixed.
Just have a manual extraction of design forces and design on Excel. it will be better.
