Discussion Groups
Robot Structural Analysis
Valued Mentor
HoshangMustafa
Reinforcement ratio
124 Views, 7 Replies
02-23-2014 09:48 AM
Hi
Please find the attached file. How can I change reinforcement ratio? I receiver an error message in column design module indicating that reinforcement is less than 1%.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Reinforcement ratio
02-24-2014 12:04 AM in reply to: HoshangMustafa
You can e.g. try to set smaller spacing among reinforcement bars.
Artur Kosakowski
Valued Mentor
HoshangMustafa
02-24-2014 05:17 AM in reply to: Artur.Kosakowski
Hi Artur
Why the reinforcement ratio is in a dialogue box in the case we can't modify it (put another value)? instead the programmer can put a reinforcement ratio implicitly in a setting. The same thing with reinforcement weight (kg/m3)
Product Support
Artur.Kosakowski
02-24-2014 06:03 AM in reply to: HoshangMustafa
I think you confuse the optimization with restrictions imposed on reinforcement distribution. that prevents generation of larger amount of reinforcement.
Artur Kosakowski
Valued Mentor
HoshangMustafa
02-24-2014 06:49 AM in reply to: Artur.Kosakowski
Hi
I wrote in the first post:
Your last post was:
Your last attachment is for a beam arrangement
Product Support
Artur.Kosakowski
02-24-2014 07:06 AM in reply to: HoshangMustafa
You missed the file. For the reinforcement pattern there situation I described is valid for both beams and columns.
Artur Kosakowski
Valued Mentor
HoshangMustafa
02-24-2014 08:30 AM in reply to: Artur.Kosakowski
Hi
Please find the attached file. How can I get rid of this error?
Product Support
Artur.Kosakowski
02-25-2014 12:51 AM in reply to: HoshangMustafa
Could you send me the rtd file with this column please?
Artur Kosakowski
