Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
saclovitzky
429 Views, 3 Replies
reinforcement maps
Hello Artur,
In trying to display the reinforcement maps, I've used the command "required reinforcement for rc slab/walls/plate and shell reinforcement(and run the calculation based on the inputted ULS and SLS combination). As you previously discussed to me that deflection on the walls is not applicable ( I mean the scaling procedure is only applicable to slabs) but I only want to view the required reinforcement maps, is it still possible/reliable to view the reinforcement maps result despite error warnings in deflection(see attached)?
3 REPLIES 3
Rafal.Gaweda
in reply to: saclovitzky
Ramon
Results are correct from caclulation = design point of view but exceeding admisible reinforcement ratio (this ratio is given by the national code).
Rafal Gaweda
saclovitzky
Hello Rafal,
Basically, what you mean is that, the reinforcement maps are correct despite deflection error result being displayed?Am I corrrect?
Rafal.Gaweda
Maps are correct  = they presents results as they are calculated.
But the results do not fulfill deflection limit => with this amount of rebars \ steel the deflection is exceeding limit set by you.
Rafal Gaweda
