Hi I'm trying to get the provided reinforcement on my slab done and for some reason it has shown the reinforcement grid at an angle see below.
Ive tried clicking on the button settin the grid to regular rather than to slab charaterics points, but that doesn't make a difference.
Your thoughts on how to solve this would be appreciated.
Solved by Lennox1973. Go to Solution.
Try to set the reinforcement direction in the reinforcement parameters label assigned to the panel in the direction you want to set the reinforcement.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Thanks Arthur, your sugegstion didn't help, but I found that my system coordinates axis (thingy) wasn't set to up, down, left right, so once I redefined by axes all was good.
