Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Reinforcement bars database
12 REPLIES 12
Message 1 of 13
Khalid-Elejla
3131 Views, 12 Replies
I want to ask about the reinforced bar database I was working on Robot 2010 and I wasn't having any problem but when I switched to Robot 2014 I found that there is a problem in the reinforced bars database
Although it was on ACI 318 metric which is the code I use in designing but I found that it isn't the usual bars diameter I usually use
I know the database depend on the region so I am from middle east steel comes to our country from Israel and turkey So what is the reinforcement database (or Specification)  used in this country
My usual database like Ø8,Ø10,Ø12,Ø14,Ø16 and named by grades (grade 360,420) So the main diffrence in the diammeters
and if I can change or modifiy the database please tell me How??
Please reply as fast as possible
12 REPLIES 12
Message 2 of 13
AhmedZA
in reply to: Khalid-Elejla
steel comes to your  country from Israel and turkey  Smiley Tongue
you can moddify database and add new diameter
how ?  save file under new name and copy it to this file path (C:\ProgramData\Autodesk\Structural\Common Data\2014\Data\Reinf)
hope this helps
Message 3 of 13
Khalid-Elejla
in reply to: AhmedZA
Thank you Mr Ahmed you are a live saver, and it worked perfectly for me I knew I had to save the XML file but I don't know were
I kinda new graduated engineer and this staff is new for me I wan to ask you If I choose 2D frame project in robot and I want to model a beam column structure which is not frame (I mean the beam and column were pured in the location separately) So what kind of support I suppose to choose I mean it's not fully pin It can resist some moment so is it OK to make it as a pin or a roller or not
Tags (1)
Message 4 of 13
AhmedZA
hi
read this (Support and Connection Types)
http://web.mit.edu/4.441/1_lectures/1_lecture13/1_lecture13.html
Message 5 of 13
Khalid-Elejla
This page was helpfully
about the main problem I thought it was solved but it wasn't after I defined the new database I tried to design a beam but I found that the problem was not actually solved I found that the reinforcement bars wasn't changed please help and I am sorry if I asked too much question but it is very important to me
Tags (1)
Message 6 of 13
AhmedZA
Message 7 of 13
Khalid-Elejla
Thank you very much I have done what you told me but there was some problems with the ACI code It is supposed to be metric and this problem was in 2014 and 2015 but it's in lb and in but thank you anyway
Message 8 of 13
napooil
Message 9 of 13
Khalid-Elejla
in reply to: napooil
I chose metric but I think I shouldn't choose ACI for reinforcement database in the first place
I think our steel is manufacture according to European specification So I supposed to choose European specification please look at this wiki page
http://en.wikipedia.org/wiki/Rebar
I think I should choose BS 4449 but I don't find it in robot but there is othere european codes in there which one you suggest the problem is we use this sizes 8,10,12,14 but strength grade360,grade420,..... So I may found other codes uses 8,10,12 but the grades 360,420,.. I didn't  found it I found instead (In BS8666 >>R,T) and (IN EN1992 >>B500C,B450
and please tell me what code you use
Please answer me I think my problem will be solved soon it's very important to Mr.Ahmed
Tags (1)
Message 10 of 13
AhmedZA
If I understand you correctly and as i can see you want to change strength 460 to 420 N/mm2 so I would suggest you to open xml file with a text edditor then try to find characteristic yield stress and change this value to 420 and use Find command to find this word quickly may be it will work perfectly with robot try to do  this by your self
(just suggestion ) because for me i had never tried it
Message 11 of 13
AhmedZA
your question has been answered by pipiyedu
Message 12 of 13
Khalid-Elejla
Thank you Mr Ahmed, and pipiyedu and Artur.Kosakowsk your for helping me it's Looks like I have to modified the DataBase, I was hoping to choose the correct database because I want to make sure it is correct in mass and max length there was slight difference in mass of the same bars in ACI phi 16 and BS phi 16 according to my tables we use BS and this will make some changes in quantities take off , take a look at the attached pictures the first which we use in my country and the other is ACI metric database I have to modify and I am afraid that there is other differences
Message 13 of 13
pipiyedu
You can change all of the atributes (mass, length, diameter, yieldstress). Try editing with a text editor.
Seems a lot of work but it is not.
