Discussion Groups
Robot Structural Analysis
New Member
rtu323
Accepted Solution
Reinforced concrete building design
1152 Views, 2 Replies
12-02-2011 05:48 AM
I have several problems with my model, not allowing reinforement design:
1. Impossible to make FEM mesh for upper plate.
2. Problem attaching beams to concrete floor. Anyone could explain how to achieve situation when beams and plate work together under loading conditions.
3. RC member design do not offer bars with diameter larger than 12 mm.
4. Required slab reinforcement tool - do not work.
I would be very glad if someone could help fixing the model.
Please use plain text.
Product Support
Rafal.Gaweda
Re: Reinforced concrete building design
12-02-2011 05:53 AM in reply to: rtu323
Check Private Message
Rafal Gaweda
Product Support
Rafal.Gaweda
12-05-2011 01:44 AM in reply to: rtu323
Change Panel Calculation Model onto Shell for thsi panel
IF the Finite Elemnts Nodes are generated over such bar it means this bar will be connected with FEs.
You can check if it is well connected by displaying "Number of Calculation Elements" after runing Model Generation or Calcualtions
Where? This is what I see
Elaborate please.
It works.
Rafal Gaweda
