What's the solution for this problem plz ??
thanks in advance
Solved by Rafal.Gaweda. Go to Solution.
i'm sure of material kind .. and i'm talking about error in the reinf.calc ??
this's the file ..
http://www.filemail.com/d/jrydkzixcvcbwtg
I don't know really .. anyway i want to ask could i design the connection between column and beam ? nd how i could get the drawings ?
but there's option for connection design in RC Elements??
Can i ask another question ?
I want to learn how i can apply wind load cases on the structure ? and get the results
thanks in advance
I ask you cuz i don't know how ! even i don't know if robot can give me the failure modes !?
thanks in advance rafal
Can you show me by short video how i applied wind load on structure .. if you want if you don't nevermind
thanks in advance
Okay i will apply loads as point load on the nodes (connect column to beam ) .. my question is i will apply this load on the outer frame and internal frame also or just for outer frames !!
