Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Reciprocal frame on Robot
17 REPLIES 17
Message 1 of 18
robmirgga
1442 Views, 17 Replies
Hello all
I am hoping to analyse a reciprocal frame with stick elements (timber beams) mutually supporting each other in a loop.These beams are simply supported at the lower end and “rest” on the next beam all round in a circle (I have attached a photo of a typical reciprocal frame to clarify)
Unfortunately my model is made up of "chunky elements" and “thining them down” doesnt allow to keep overall geometry.
 reciprocal 3.pngstick elements not intersecting.JPGconnections using rigid links.JPG
In the robot model called reciprocal 3D I have tried by “bending” beams to fit geometry  while in “structure” I have “played” with the connection to work at offset (this doesnt not work though)
I have also attached a flat analysis model in “reciprocal”
Maybe I should be modelling beams as 3D elements? (I have tried this but results are more complex to check!)
I was wondering whether there was an option in Robot which allowed to insert pinned connections at an offset / distance? Maybe I am looking at this in the wrong software?
17 REPLIES 17
Message 2 of 18
Try the following approach:
1. Model the beams as they are in reality (a bar in Robot being the center line of a real beam)
2. Connect 'bottom' and 'top' beams with rigid links defining the master node at the bottom beam and the slave with released rotations at the top one.
Artur Kosakowski
Message 3 of 18
Thanks Arthur
So these rigid links would in effect be "offset" pinned joints?
Message 4 of 18
They should work like that.
Artur Kosakowski
Message 5 of 18
Thanks for your help.
I will try this out and post reply later today or next week.
Regards
Message 6 of 18
When you release rotations for rigid links you should not define bar releases at the same locations. Delete the releases in the model you sent me and you should be fine.
Artur Kosakowski
Message 7 of 18
robmirgga
in reply to: robmirgga
Fixed!
Thanks for your help!
Roberto
Message 8 of 18
I am working on a similar structure (see screenshots below) and have read a couple of research papers which suggest that if the top of the members are suitably tied with rigid connections then no lateral thrust should occur at the base. I have therefore modeled roller supports at the base of the rafters but am getting some instabilities and large lateral deflections. Presumably this is to do with the way the top connections / rigid links have been modeled?
Message 9 of 18
can you send the model?
Rafael Medeiros
Message 10 of 18
Please see model file attached.
Many thanks
Daniel
Message 11 of 18
Mathematically ,Robot doesn´t accept a 3d structure without horizontal supports even if there will be no horizontal reactions ,like in a lifting situation.
The workaround I use is to set very weak horizontal springs, Doing that you will get the results you expect
Rafael Medeiros
Message 12 of 18
Fantastic! Many thanks for your help.
Message 13 of 18
Hi @daniel.hubbard
Do you mind marking Rafael's post as the solution so that it is easier to find? Thank you.
Artur Kosakowski
Message 14 of 18
Of course. How do I mark it as the solution?
Best regards
Dan
Message 15 of 18
Hi @daniel.hubbard
You should be able to press such named button
Artur Kosakowski
Message 16 of 18
I do not have an accept as solution button visible. Perhaps because I commented on an existing thread which has already been marked as solved?
Message 17 of 18
Hi @daniel.hubbard
I don't think it is related. I will mark the solution on your behalf and at the same time I'll ask the Forum Team if they are able to find out why you can't see it.
Artur Kosakowski
Message 18 of 18
Hi @daniel.hubbard
Indeed your assumption was correct. You can't see the button as you are not the person who started this topic. I could move your post and the its answers to a new topic and then you would be able to do this but as your question IMHO is very much in the line with the original topic I'd rather leave it as it it is with the solution marked by myself.
Artur Kosakowski
