Discussion Groups
Robot Structural Analysis
robmirgga
Reciprocal frame on Robot
473 Views, 6 Replies
01-25-2013 03:30 AM
Hello all
I am hoping to analyse a reciprocal frame with stick elements (timber beams) mutually supporting each other in a loop.These beams are simply supported at the lower end and “rest” on the next beam all round in a circle (I have attached a photo of a typical reciprocal frame to clarify)
Unfortunately my model is made up of "chunky elements" and “thining them down” doesnt allow to keep overall geometry.
 reciprocal 3.pngstick elements not intersecting.JPGconnections using rigid links.JPG
In the robot model called reciprocal 3D I have tried by “bending” beams to fit geometry  while in “structure” I have “played” with the connection to work at offset (this doesnt not work though)
I have also attached a flat analysis model in “reciprocal”
Maybe I should be modelling beams as 3D elements? (I have tried this but results are more complex to check!)
I was wondering whether there was an option in Robot which allowed to insert pinned connections at an offset / distance? Maybe I am looking at this in the wrong software?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Reciprocal frame on Robot
01-25-2013 03:47 AM in reply to: robmirgga
Try the following approach:
1. Model the beams as they are in reality (a bar in Robot being the center line of a real beam)
2. Connect 'bottom' and 'top' beams with rigid links defining the master node at the bottom beam and the slave with released rotations at the top one.
Artur Kosakowski
robmirgga
01-25-2013 03:52 AM in reply to: Artur.Kosakowski
Thanks Arthur
So these rigid links would in effect be "offset" pinned joints?
Product Support
Artur.Kosakowski
01-25-2013 03:54 AM in reply to: robmirgga
They should work like that.
Artur Kosakowski
robmirgga
01-25-2013 04:43 AM in reply to: Artur.Kosakowski
Thanks for your help.
I will try this out and post reply later today or next week.
Regards
Product Support
Artur.Kosakowski
01-28-2013 12:33 AM in reply to: robmirgga
When you release rotations for rigid links you should not define bar releases at the same locations. Delete the releases in the model you sent me and you should be fine.
Artur Kosakowski
robmirgga
01-28-2013 12:13 PM in reply to: robmirgga
Fixed!
Thanks for your help!
Roberto
