I have a structure in which some of the columns are not alligned with the global axis system i.e. 4 corners forming a 90 degree curve in the corner of a building (0, 30, 60, 90 degrees - see attached image).
If I rotate the supports (shown circled in red) at the bases of these columns so that they are aligned with the individual columns is it then possible to see the values of the Fy and Fz reactions in terms of the support/column orientation and not in terms of the global axis orientation, which seems to be standard method of displaying the reactions.
If i could get the results in this fashion it would help with the foundation/baseplate design,
Anyone any suggestions?
Solved by Artur.Kosakowski. Go to Solution.
